F-20 Mistake not good my fault or Not
Eric
06-11-2004 21:01:45
well today i got my 38 f-20 painted tonight i put everything back together well i went to start it ok i think im good at this kinda stuff im only 14 i put the plug wires on wrong well it started and was back firing so i shut it down and put plug wires on right way got it running sounded good opened it wide open for a while then i heard a crack and oil was comin out of the frost plug took it out and there was a broken rod bolt and the cap was twisted all over the place and i brock the a chunck of the sleeve off wat should i need to do to get it running and wat would i have to do to get it running perfect who kows if it was my fault or not you can something about that too if you want
Dave in CT
06-12-2004 10:59:22
 Re: F-20 Mistake not good my fault or Not in reply to Eric, 06-11-2004 21:01:45
May have been running it wide open too soon. I would've thought tractor engines take so long to warm up this would not be a threat but I guess it is. I don't use my H for anything but hour-long tasks. I've confirmed the operation of the thermostat and temp meter and the needle never registers anything while in operation. Let us know if you find it's something else like a blocked oil port, etc. Sorry for this episode but you're already way more experienced than I in disassembly/reassembly.
Farmallkid
06-12-2004 05:18:06
Your learning just like me. First I cracked the block on our A towing it, then i cracked the hydraulic pump on my M/SM. So welcome to the club, I'm 16, And i dont know a thing about tractors compared to some of the guys on here
nebraska cowman
06-12-2004 06:18:55
 Re: Re: F-20 Mistake not good my fault or Not in reply to Farmallkid, 06-12-2004 05:18:06
ya, but you're learnin' fast kid! I just cleaned up the live pump. it looks real good and is an m&w. I bet it brings $200. I hope I can get some stuff listed later today, I'll send you the link.
nebraska cowman
06-12-2004 04:14:35
sounds like a complete teardown to fix it right. start by pulling the piston out the bottom. If you think th sleeve is not hurt too bad you might not have to pull the head. I have used parts. And next time don't let it run wide open, they will self-destruct
Ron
06-11-2004 21:45:51
Sorry to hear of your misfortune...
Sounds like maybe someone over-torqued a rod bolt.. Hope you can get it back together.
steveormary
06-12-2004 12:43:07
 Re: Re: F-20 Mistake not good my fault or Not in reply to Ron, 06-11-2004 21:45:51
Dave in CT;
Probably running it full throttle too soon. But I have done that and never had a problem.
steve
Dave in CT
06-13-2004 08:25:09
 Re: Re: Re: F-20 Mistake not good my fault or Not in reply to steveormary, 06-12-2004 12:43:07
Well, I thought that might be a bit over-cautious with a tractor engine so, we'll see if he can find something to link the cracking to directly.
