steering quit working on 350 rowcrop
joe
06-14-2004 18:35:27
was out mowin today and a mile from home steering quit. shaft that goes into steering box on top turns the big gear but nothing else happens. i took the nut off but what next. do i disconnect the steering shaft and feed it out of the front nut on the bolster? what suddenly stopped working. how does the gear come out?
joe, followup
06-14-2004 18:43:51
 Re: steering quit working on 350 rowcrop in reply to joe, 06-14-2004 18:35:27
the shaft that runs up into top bloster via the frame does not move, so the problem appears to be in the gear box itself
Jim J
06-14-2004 20:36:07
 Re: Re: steering quit working on 350 rowcrop in reply to joe, followup, 06-14-2004 18:43:51
A very common problem is that the upper bolster shaft breaks off at the thrust bearing.
Carp
06-14-2004 19:32:42
If you havn't already, pull the 4 bolts off the top cover and remove it. I would bet that the key in the steering sector is sheared off. Should be fairly easy to fix if that is the case.
Hoppy
06-15-2004 06:02:12
 Re: Re: Re: steering quit working on 350 rowcrop in reply to Carp, 06-14-2004 19:32:42
I'd guess it the splines are worn off of the short shaft just as it goes into the sector. If that's the case you can drill a hole through the connection and install a roll pin.
