Wide Front ends
David
06-14-2004 21:48:44
I just bought a 656 w/narrow front. I found a good price on a wide front at a tractor salvage yard. They said that it was for a 656 so I bought it.
Just wondering if the same wide front was used on M's through 686 or did they change over the years.
The one I bought is different than many I have seen. Rather than Large nuts on top of the king pins, the levers that turn the spindles are attached with smaller horizontal bolts.
I'm looking for a wide front for my 300 also so any general info on IH wide fronts would be appreciated.
Novel Idea Guy
06-15-2004 06:55:25
 Re: Wide Front ends in reply to David, 06-14-2004 21:48:44
Sounds like a Schwartz to me. The arms basically "clamp" on, right? Nothing wrong with a Schwartz front end, just not original.
Scott
06-15-2004 19:21:15
 Re: Re: Wide Front ends in reply to Novel Idea Guy, 06-15-2004 06:55:25
I have a IH wide front on my 706 that has the crossbolt clamp type steering arms. I think they may be aftermarket replacements, one thing for sure they will never work loose like the factory type. You can tell a factory IH wide front by the center bolster that bolts to the tractor, if its cast its IH, if its made of welded steel its aftermarket.
Hugh MacKay
06-15-2004 02:04:06
David: M wide fronts were didderent in that tyrods were out front. From Super M through 656, basic design stayed the same, few changes in length of steering control arms to give shorter turning. The 666 and 686 were a bit different although will bolt up, tyrods will be different as those two tractors used an external cylinder for power steering.
Scott
06-16-2004 20:31:41
 Re: Re: Wide Front ends in reply to Hugh MacKay, 06-15-2004 02:04:06
My 686 uses the steering gear built into the front bolster like the 656, M ect. No external cylinder.
