Order Farmall Cub Parts Online
Cub rear seal leak
Rodger in Sabul
06-20-2004 19:00:14
Is it possible to replace the rear seal without splitting the tractor? Also, does the seal tend to leak if the oil is overfilled?
john *.?-!.* cub owner
06-20-2004 20:44:38
 Re: Cub rear seal leak in reply to Rodger in Sabula, 06-20-2004 19:00:14
No, it has to be split. also ther is a problem that if you have an older model the original seal has a slightly smaller o.d. than the current ones, and you must either buy a new seal retainer or use some type of sealer such as wind shield seler to keep it from leaking. Being overful will not make the seal leak. If your cub is manufacturing motor oil you probably have a seal leaking in your hydralic pump.
