H,Carb
Don
06-27-2004 06:13:28
What goes in the drip hole on the H carb. Must be some kind of packing? Timing is it on the first notch? It has a mag. When igot it. it was on th
2nd notch. B00k says 1st.
Thank
Dave S.
06-27-2004 13:08:16
 Re: H,Carb in reply to Don, 06-27-2004 06:13:28
A felt disc goes in the drip hole. Do not leave it open or it will suck dirt into the engine and and ruin it in time.
Dave
06-27-2004 08:45:03
There is a special disc that goes in there. Just buy the IH rebuild kit for it and it should be in the kit.
Dave in CT
06-27-2004 08:05:20
Static timing is to the first notch. I've had more experienced folks tell me timing it to the 2nd notch assures it won't kick back when starting with a crank. I believe there's a felt packing that goes in the drip hole. This allows excess gas to evaporate when shut off.
On2Wheels
06-27-2004 06:51:45
As far as I know the drip hole is for overflow in the carb and I don't believe anything goes there. As far as the timing, follow the book, but I would also compare how she runs from notch to notch.
