Super A wheel problem
Bill
06-30-2004 04:54:09
I have a 53 Super A, I have been mowing the fields with a sicklebar and it works great! Plowed snow all winter too, here in VT. I noticed the last couple of times when taking her out, that the right rear wheel has a very noticable click about every revolution...I can here it with the engine running and ear protection on. Both in forward and reverse gears. Any ideas on what that is?? Also I am very interested in getting a rough cut rear mower to run on the live PTO, even tho it's offset. Anyone got one? Or know a source of supply?? Thanks
Hugh MacKay
06-30-2004 07:56:21
 Re: Super A wheel problem in reply to Bill, 06-30-2004 04:54:09
Bill: As others said, loose wheels. tighten them quick before you wear the mounts, and can never keep them tight.
scotty
06-30-2004 05:31:51
Bill, You hit the nail on the head! Those are your bolts loosening up and allowing the wheel to move on every rotation. I had the same problem on my 42A while mowing with the 16A rear mount sicklemower. Get new bolts and new lockwashers and problem solved. You can get a 4ft towbehind brushmower, it will be offset since your pto is offset.
Where in Vt, Im in East Wells 20 mins southwest of Rutland.
scotty
Ed
06-30-2004 05:13:44
Mine does the same thing. I pretty sure it's caused by the bolts holding the rim to the wheel loosening up.
Ed
Bill
06-30-2004 10:06:03
 Re: Re: Super A wheel problem in reply to Ed, 06-30-2004 05:13:44
Hugh, Ed and Scotty,
Thanks for the followup! I'll tighten them up ASAP! Scotty, I am in Waterford about 4 miles east of St Johnsbury. Used to play hockey in Rutland many years ago (we were the visiting enemy). Old Royce Mandigo areana (new then).
Thanks fo rtheinfo.
