10 20 Float Level
Tony
07-01-2004 05:02:19
Hi I was wondering if someone out there could give me the correct float level setting for a 29 McCormick Deering 10 20 Thanks
Greg (TX)
07-14-2004 17:24:46
 Re: 10 20 Float Level in reply to Tony, 07-01-2004 05:02:19
Tony,
Here is some information I found on another post while looking for information.
Good luck,
Greg
Posted by Bob Kerr on July 01, 2001 at 16:09:08 from (205.188.199.41):
In Reply to: Carb float posted by Bottom D on July 01, 2001 at 08:18:14:
You can coat the float with gas tank sealer. Originally they used shellac on cork floats which works fine if you don't have ANY alcohol in the fuel. Alcohol will dissolve shellac. If you bought a new float for your 10-20 I know exactly what you mean about the bubbles. The new float I got had bubbles and it caused the float to hang up at the end opposite of the brass tang. I took a file and filed the coating until it cleared.Also throw out the directions for seting the float! It will run way too rich if you set it to the spec they give. Look on the inside of the carb fuel bowl and you will see a groove cut into the inside of the bowl all around. Set the end of the float to the groove.Works perfect! It will start easy and be easy to adjust the carb when you have it running. I have a feeling they cut that groove for the guys to use as a guide when putting the carbs together on the assembly line.
