goo to hold sleeve in 282d
Chris Brown
07-07-2004 05:05:52
I have read about stuff to put on the sleeves in the 282d to take up the gaps between the sleeve and the block.Where can I get some?
K.B.
07-07-2004 21:10:13
 Re: goo to hold sleeve in 282d in reply to Chris Brown, 07-07-2004 05:05:52
I've heard that you can get sleeves for the 282 with a larger OD. Of course, this means you'll need to have the block bored out a little.
Farmall 650
07-07-2004 18:26:42
The last 2 D282's I did the sleeves were a press fit but Locktite makes a sleeve retaining compound there are a different kinds for the size of gap you have a local parts house should be able to help you with the Locktite
nebraska cowman
07-07-2004 10:41:47
gap????? ???? i thought there were a press fit?
lee
07-07-2004 20:19:50
 Re: Re: goo to hold sleeve in 282d in reply to nebraska cowman, 07-07-2004 10:41:47
I would have a real problem using some kind of filler. If sleeves were a slop fit I would pull the engine and take it to a shop to have sleeves
fitted. I would have sleeves fabricated before I
would go to goop or filler. These are just my thoughts. Opinions may vary.
Chris Brown
07-07-2004 10:47:33
All the 282's I've been around fit loose even though they are supposed to be pressed to fit.Lots split the sleeve after a few hundred hours. I have read here about sleeve glue or something like that to fill in any low spots and keep them ffrom cracking,old timers call it sleeve pucky.
