Difference between 113 and 123?
phillip
07-07-2004 17:58:23
Are the heads interchangeable? Cranks? I know the bore is different. What is the difference in the blocks? I have a 123 with the front broke off, but I have a locked up 113 with a good block. I was wondering what I could do to make one good one for my Super C. Thank you
parts man
07-07-2004 18:38:37
 Re: Difference between 113 and 123? in reply to phillip, 07-07-2004 17:58:23
The only real difference is the thickness of the sleeve wall and the diameter of the piston, BUT, in the 113 and 123, there are 2 different size bottom sleeve diameters. If your sleeves match at the bottom, you can interchange all the internals.
