350 carb
Lary
07-07-2004 20:25:39
Can the carb. on a 350 be removed without taking the manifold off? I can't seem to get the back bolt. thanks in advance Lary
ChadS
07-08-2004 07:55:41
 Re: 350 carb in reply to Lary, 07-07-2004 20:25:39
I made a wrench just for that back carb bolt, just heated up an old 9-16 wrench, bent it so it gives a bit more room, fits right on! Hope this helps. ChadS
Rich-Wi
07-08-2004 03:59:56
I've had to get a small vise grip on the stud and take it out by putting the vise grip between the carb and the manifold, then turning the stud out.
TDK
07-07-2004 23:13:11
After removing carb. run a tap through the nut and maybe even a thread die over the stud. After doing this you'll be able to run nut all the way up by hand & then only have to use wrench to tighten. Worked for me!
Marvin(MN)
07-07-2004 22:23:21
I use a right angle openend wrench on my 300U. HTH
steveormary
07-08-2004 08:51:30
 Re: Re: 350 carb in reply to Marvin(MN), 07-07-2004 22:23:21
Lary;
Chads and others are right. Just make a wrench for it. Had to do that for my 300.
steve
