m farmall piston rings
pedro texas
07-10-2004 12:34:21
need some help on farmall m piston rings set the set i order#a 1486869 are to big,#inside piston 1727,loex,Alcoa.hope some can tell me the right set of rings .
justin
07-10-2004 19:56:52
 Re: m farmall piston rings in reply to pedro texas, 07-10-2004 12:34:21
Being a lo-ex piston, strange things sometimes emerge.. the 1727 indicates that the piston was produced for sealed power. The number does not show up in my sealed power book, but does cross reference in my perfect circle interchange to an old PC# 1049P. A master piston ring interchange should be able to match the rings to the piston, otherwise you will have to order each individual ring by bore diameter x ring thickness x ring depth. if I can find anymore info for you, I will post it..
nebraska cowman
07-10-2004 13:12:27
If you measure the diameter of your pistons and the width of each ring and the number of each you need any parts man should be able to get you the right ones.
pedro texas
07-13-2004 22:41:10
 Re: Re: m farmall piston rings in reply to nebraska cowman, 07-10-2004 13:12:27
back to my piston i took it to machine shop the piston 4" top ring 3/32 #2=3/32 #3=1/8 oil ring 1/4" hope some one hnows where i can get a set thanks from all of you who been helping me.
