Farmall A problems (novice)
Andrew
07-18-2004 19:33:58
I just got a 1945 Farmall A, the tractor had not been really worked in over 5 years. The two problems that I have is the lights were working fine then all of a sunden the lights "all of them" went out (is there a fuse some where cant seem to find one) The other problem seem I seem to notice that there is a leak around the 1st cylinder there is a little bit of oil or coolint leaking out just in that area no where else, is this all right or do I need to replace the head gasket? Sorry this is going so long but I have one last question what should the normal oil pressure should be. At first the pressure is high then after it backs off on the pressure is this normal operation? Thanks for the help!!
Andrew
Haas
07-19-2004 06:12:53
 Re: Farmall A problems (novice) in reply to Andrew , 07-18-2004 19:33:58
If the leak is around the head gasket, I'd try removing the valve rocker cover and the rocker arms shaft assembly and retorque the head bolts. It's necessary to remove the rockerarms and shaft to get to the head bolts. You'll have to reset valve rocker arm clearances when you reinstall the rocker arm assembly. Get a new gasker for the cover and also make sure you align the notch in the rocker arm shaft with the stud bolts when you reinstall. I've seem some specs that say 60 ft-lbs for the head bolts and others say 80. I've always used 80. If retorqueing does not stop the leak, they you will need to replace the head gasket. All this assumes you do not have a crack in the block or head. Usually a crack in block is just in front of carburetor on the side of the block. That does not sound like yours. As to the lights, you will just have to trace down the wiring. Could be a bad switch or bad ground.
Eric
07-18-2004 21:51:49
sounds maybe that the block is cracked where exactly does it leak oil??? and it shouldnt be leaking out of the head gasket anyways :snds like an experts work to me hpe the info helps
