Regulator Problems
Super H
07-20-2004 05:24:39
I've had my 1950 Super H for about 20 years and it has been an awsome tractor for my needs. I've had a problem with the regulator not lasting, if I am lucky it will last a year then go to negative charge.
It's a 6 volt system, positive ground, generator works fine, new battery. It's all original and I am wondering what could cause this.
Also the small valve that controls the carb float must be worn out as it sticks, have cleaned it up a few times but was a pain dueing a storm last winter to keep it moving. Does thismetal valve come with a carb kit?
Thanks a bunch
Andy in Nova Scotia
Pete
07-20-2004 14:09:36
 Re: Regulator Problems in reply to Super H, 07-20-2004 05:24:39
Take the bad regulators to someone who
knows them inside and out to find out what
part of the regulator failed that will get you a starting point.
Matt
07-20-2004 07:18:21
If you can find a rebuild kit for your tractor, it should have the float valve.
