SMTA---TA Question
ds
07-20-2004 17:44:28
I am looking at a SMTA that was restored 6 years ago. At that time the owner replaced the TA and the small clutch and claims the TA worked fine. The tractor has sat outside for the past 5 years and has not been run. We got the tractor running and everything seems to work ok except the TA. It seems to be locked in the high side in 1st, 2nd, 3rd, and 4th. When I shift the TA down nothing happens but the tractor stays under power. When the tractor is in 5th gear the TA works fine. I am a little puzzled why the TA will not work in the lower 4 gears but works fine in 5th. Does anyone have any ideas or advise? Thanks
Hayfarmer
07-20-2004 22:21:05
 Re: SMTA---TA Question in reply to ds, 07-20-2004 17:44:28
The first step would be to make sure it is adjusted correctly. The adjustment is detailed and requires an owner's manuel or service manuel. If the TA slips in low range, stops when you shift the lever back, it is usually caused by the ramp and roller being bad. If it slips in the high side it is generally the ta clutch slipping. Since yours will not go into the low range my guess would be that the ta clutch plate is stuck or sticking. Perhaps it will owrk in 5th because ther is more pressue against it. There is a plate on top of the ta section, ahed of the belt pully. If you take the cover off you can look in on the ta clutch and may be able to see if that is the problem. Otherwise maybe if you try it under load and pull the lever back it might come loose. Of course when it does part of the lining may stay attached to whatever it is stuck to. I am not sure how much work you can do through the plate on top of the ta. The TA pressure plate is similar to the main clutch plate in that you can put some bolts in from the back to hold the plate under pressure, then remove the 3 bolts that hold it to the "flywheel or driven surface. The service manuel describes this procedure. If you can release the pressure plate you should be able to get the clutch plate loose. Let us know how it goes.
