Charlynn Power drive motor angle is all wrong??
jonesy
07-21-2004 08:10:23
I got to mounting the drive motor and bracket on the tractor and it didnt even come close to macking the angle of the steering shafts. Its like it needs a wedge type shim or something. If someone has one mounted could you send me some pictures?
42FarmallH
07-21-2004 12:20:02
 Re: Charlynn Power drive motor angle is all wrong? in reply to jonesy, 07-21-2004 08:10:23
Dave has posted my website below with pics of what you need. I had a machine shop build mine for like $10 or $15, they are $65 from steelwheelranch.com.
I'm assuming you're working on an H, if you're working on something else I don't know what to tell you...
jonesy
07-21-2004 15:10:40
 Re: Re: Charlynn Power drive motor angle is all wr in reply to 42FarmallH, 07-21-2004 12:20:02
The post was quite helpful. I believe that I will go the machine shop route as well. Im working on a M.
42FarmallH
07-21-2004 20:19:31
 Re: Re: Re: Charlynn Power drive motor angle is al in reply to jonesy, 07-21-2004 15:10:40
Take them the measurements, a picture, and a torque motor to be sure it fits nice...
Dave
07-21-2004 08:29:05
Whoops, let's try that again - try:
Link
Dave in CT
07-21-2004 08:24:29
Look at http://www.geocities.com/farmall544/livehyd1.htm
Farmall Nut
07-21-2004 21:54:37
 Re: Re: Charlynn Power drive motor angle is all wr in reply to Dave in CT, 07-21-2004 08:24:29
shim the rear by adding washers, many old units I have seen have an xtra washer or two under the rear of the steering motor....whatever works
