dust deflector
ihfan2
07-21-2004 19:07:52
Could anyone tell me where I could find a dust-dirt deflector on the inside of the wheel and seal on a '49 M? All help would be appreciated. Thanks
TDK
07-22-2004 20:51:34
 Re: dust deflector in reply to ihfan2, 07-21-2004 19:07:52
I believe I know what you're talking about. It's called Front Wheel Dust Shield-IH#48701 D. The Felt Washer is IH# 48702 D. Grease Seal is IH# 358779R91 or C/R# 20735. You can probably get most of these from your CNH dealer with exception of the dust shield. The seal can most likely be bought from an auto parts store using the C/R number. For the parts you cannot find, I'd do as CNKS said and call Steel Wheel Ranch at 1-913-548-7473.
CNKS
07-23-2004 18:47:42
 Re: Re: dust deflector in reply to TDK, 07-22-2004 20:51:34
Think I was talking about the wrong end of the tractor. NE Kansas area code is now 785.
CNKS
07-21-2004 19:18:57
If you mean the felt seal, Case-IH still has them.
ihfan2
07-21-2004 19:54:34
 Re: Re: dust deflector in reply to CNKS, 07-21-2004 19:18:57
This is a cast iron piece. I have not seen it dad has been tinkering with it
CNKS
07-21-2004 20:13:06
 Re: Re: Re: dust deflector in reply to ihfan2, 07-21-2004 19:54:34
Not sure what you mean, must be the cap on the end of the axle housing? Anyway, call Steel Wheel Ranch 785-548-7437. Mike has nearly everything.
