Fuel Guage on a 806
Marty Peru
07-22-2004 14:48:03
Hi everyone, I have a 806 Desiel that is working very well. The fuel guage is not working. I have checked for loose wires but I think it is the sending unit. How hard is it to change.
Thanks
Allan in NE
07-22-2004 16:04:58
 Re: Fuel Guage on a 806 in reply to Marty Peru, 07-22-2004 14:48:03
Hi Marty,
Just repaired one; they are the simplest repair ever: Unplug the 2 wires at the sender and take out the 5 little screws holding the sender into the tank (after you remove the hood, of course).
But first, to test the sender, take the sender wire (not the ground wire) and ground it. The gauge should then go to full. Likewise, an open circuit on this wire should produce an empty reading on the gauge.
Hope this helps,
Allan
