Farmall 544 info request
Jim Crain
07-23-2004 07:22:31
Going to look at a 544 diesel tomorrow. Guy says TA and PTO don't work rear tires beat. Says has 2 hyd pumps. 3pt and sterring fine. Wants $2000. Can the TA be worked on externally or do I have to spilt the tractor ? Also is the PTO easily accessable to work on ? I am good with cars/trucks but new to tractors. Would this be worth buying or are there to many headaches?
Texas Red Iron
07-23-2004 17:41:04
 Re: Farmall 544 info request in reply to Jim Crain, 07-23-2004 07:22:31
Hey Doug. For my money the IH 484 utility is the tractor. With the German D-179 40+hp diesel. Live PTO, hydraulics, power steering, wide fronts, 3 pt. hitch, remote hookups for loader or what have you, 4 spd. with Hi-Lo gives you 8 gears. Great power! And you can buy them for around $3500. Much more tractor for the money and you don't have to mess with TA's.
Dr.EVIL
07-23-2004 12:44:50
Have to split the tractor for R&R of the T/A. LPTO gearbox is external mount on the very back if That's where the problem is. If not the problem is probably up by where the T/A is....
p-c-y
07-23-2004 07:40:19
for 3500 i will sell you one that will go to the feild ,
Tom Ritchey
07-23-2004 13:38:13
 Re: Re: Farmall 544 info request in reply to p-c-y, 07-23-2004 07:40:19
If you live close to Harrisburg, Pa. 17111, I'd be interested in the Farmall 544 for $3500,
Jim Crain
07-23-2004 07:52:55
Is it a 544 ? Where you at ? I'm in Vermont. If not to far away I may be interested.
