?SN on Farmall M
Mike in MT
07-29-2004 07:40:59
Can anyone tell me where to look for the serial number on my Farmall M?? It has many numbers stamped all over. Mike
rustyfarmall
07-29-2004 09:05:48
 Re: ?SN on Farmall M in reply to Mike in MT, 07-29-2004 07:40:59
There should be a small steel or aluminum plate, held in place with 4 rivets, on the left hand side of the tractor. It should be on the clutch housing, below the oil bath air cleaner. If it is not there it is because someone has removed it. Also, I think maybe the very early 1939 models may not have had this plate, in which case you would want to look for the number stamped into the top of the frame rail, I don't remember if it is the right side or the left, or whether it is towards the front or the rear.
William Ransom
07-29-2004 08:58:26
The serial number tag is on the clutch housing, near the starter (on the left side of the tractor). The serial number begins with "FBK-".
