metal parts in oil of MD
TIm
07-29-2004 17:28:33
I found a grounded up washer and bits of gear teeth in oil when i changed my oil. The washer shows signs of wear and looks like it fractured then went through a gear. Is there a washer on the oil punp by the gear as a shim? Where can i find drawings of the engine on line. It is a 1950 farmall M diesel. It still runs great.
Thanks, Tim
riverbend
07-30-2004 21:40:21
 Re: metal parts in oil of MD in reply to TIm, 07-29-2004 17:28:33
How is your oil pressure ? The broken gear teeth do not sound good.
My H has screen over the oil pump pick up. It would be hard for any good sized piece to get in. The oil ways are fairly small, so it would be hard for any size chunk to circulate and drop into the oil pan.
The best diagrams are in your parts book. Either you can run it until it blows up or you can take the motor apart and have a look. Taking it apart now will be far cheaper than letting it blow.
