What Failed?????
scotty
08-02-2004 04:32:47
Over the weekend I caught up on some of my reading, and had a chance to read Guy Fays article on the IH demise of the 560, Nov/Dec issue I believe. Excellent article, but was wondering what was failing on this tractor, axles,transmission etc? Please excuse my ignorance but all my tractors are smaller. I found it very interesting that JD went from the 720 to the 4010 with a jump of almost 30 hp without changing the driveline components and they had failures also. Was the 560 tractor the next generation after the Super MTA? Just thought that alot of you guys went through some of this.
Thanks
scotty
RPM
08-03-2004 07:52:52
 Re: What Failed????? in reply to scotty, 08-02-2004 04:32:47
Interesting comments from people around the country, could add a lot of comments from personal experience working at a IH-CNH dealer since I was 19, still am at 62, fast hitch simply wasnt tough enough for higher hp, first 1206 had a form of 2 point, 560 was stopgap tractor until 806 came out, 4010 wasnt much of a heavy tillage tractor, here in Iowa in the later 60 and into 70 before no-till, the bigger the better, yes IH had a lot of goofs, and they wouldnt listen, labor problems, arrogant managers higher up. IH at that time was actually run by the MT (truck) division, it wasnt official but at the dealer level you could tell. They started selling off divisions to save their butts in truck.
Tim in NB
08-03-2004 12:33:27
 Re: What Failed????? in reply to RPM, 08-03-2004 07:52:52
They even had to get rid of the smaller trucks too. 75 was the last year for pick ups and 80 being the last year for the scouts. Then there was the cub cadet line after that.
K.B.-826
08-02-2004 19:58:33
Check out a 560 parts manual sometime. The 5-speed gear box in the first 560's is almost identical to the one in the last 560's, so that was not the problem. Now check out the pages on the differential. The differential was totally changed about halfway through production. At the top of the page, it will say something like "stamp a triangle on serial number tags of early production tractors after installing updated differential". Finally, check out the page on the final drives. About the only change there was the inner axle bearings. 1960 was the year that Deere got ahead of IH. IH's big row-crop tractor was the 65 horsepower 560, and Deere comes along with the 80 horsepower 4010 (totally different from the 2-cylinders) which had a transmission and hydraulics that were way ahead of their time. Deere used that transmission right up to the '90's, and that hydraulic pump is still being used today.
Hugh MacKay
08-02-2004 13:28:43
scotty: I haven't seen this article and probably won't see it. Is this article about the IH demise or the failure of the 560 just being part of that demise.
The demise started with fast hitch and fast hitch was a far bigger factor in the demise of IH than any failure of the 560. Harry Ferguson had won the hitch war before IH sold its first fast hitch on the Super C in 1952. For 10 years IH continued to flog the fast hitch while customers buying 30 to 50 hp tractors and related equipment were leaving in droves, as they didn't want to be married to fast hitch. They wanted a universal hitch so if the mower or plow from MF, JD, Ford, etc was a better buy they had options. Many of these customers left IH never to return.
Yes the 560 rear end and transmission had problems in the first 3 years, but that was only aprox. 36,000 tractors. Close to that many more 560's were manufactured after that with no problems. I'd be willing to bet glow plugs in tractors, between 1958 and 1965 cost IH a whole lot more business than the 560 did.
In my opinion that 560 issue has been blown away out of proportion in the demise of IH. If you look at the number of owners that had two of them, probably somewhere in the order of 30,000 customers were affected by the 560 problem. That is peanuts across North America.
CNKS
08-02-2004 18:39:15
 Re: What Failed????? in reply to Hugh MacKay, 08-02-2004 13:28:43
You could get 3-point adapters to use with fast hitch -- I just bought a 460 HU with one, looks ok to me. I think the 460/560 fiasco, along with other instances of IH releasing tractors before the engineers were ready to was a far bigger problem. They had a couple (at least) of lousy CEO's. The TD (forgot the number) was recalled and scrapped. Although, failure to meet the competition, in this case mainly Deere, was the biggest problem. Deeres new generation tractors killed IH, although it took 25 years. Along with continual labor-management problems. Deere wanted IH to license fast hitch to them -- If IH had done so, fast hitch would be the standard, not 3 point. Case had their Eagle hitch, somewhat similar to fast hitch, I imagine they would have converted to fast hitch, also.
Hugh MacKay
08-02-2004 20:24:15
 Re: What Failed????? in reply to CNKS, 08-02-2004 18:39:15
CNKS: I know all about 3 point adapters, those only created not solved problems. Yes I agree, had IH taken the Deere proposal, things would have been different. I'm not sure they would have been as different as you think. At the same time IH was flogging fast hitch across North America, they were installing factory 3 point hitches on Farmalls both in Europe and Austrailia. I stand by my statment that Harry Ferguson had won the hitch war before IH sold their first fast hitch.
I quite agree it was 25 or 30 years of mismanagement that took IH down. My point is of the couple million farmers across North America at that time, roughly 30,000 of them would have had trouble with a 560. No question, 560 was part of it but only a small part.
CNKS
08-03-2004 11:39:03
 Re: What Failed????? in reply to Hugh MacKay, 08-02-2004 20:24:15
I will agree that IH held onto fast hitch too long, and that it was part of the problem, but actually part of a bigger problem, in that they were simply too slow to meet the competition, fast hitch or not. JD first outsold IH in 1958, (BEFORE the new generation), IH was never #1 again. I was 20 years old when the 460/560 were first produced -- that's about the time I left the farm so I had no experience with them. I remember my dad saying that his dealer told him the tractors just had too much power, causing drive train problems. At the time I thought it was a whole new tractor, it was except it had the H/M (ok, 350/450 rear end) and was released over the objection of the engineers. It's not just the number of farmers affected -- it damaged IH's reputation to the point they could never recover.
Hugh MacKay
08-03-2004 17:15:54
 Re: What Failed????? in reply to CNKS, 08-03-2004 11:39:03
CNKS: Fast Hitch also had another side to it. In my opinion it was the forerunner of 3 point perfection. Harry Ferguson didn't have it all right either. Fast Hitch was the pioneer of lower link sencing for draft control. There is no question in my mind the very finest draft controled hitch came on 06, 26, 56, 66 and 86 series tractors. I am most familiar with the 3 point but expect fast hitch on the 06 and 56 used the same principle of draft control. Next time you are at a show or around 06,26,56,66 and 86 series tractors with 3 point hitch. You look the lower link over. That telescoping end is clearly fast hitch decendant. There was indeed some good came out of fast hitch.
Here in Canada dealers took a real hit from MF, Ford, Fiat, etc. in the 2-3 plow tractor business. Farmers wanted 3 point so IH started bringing in those 30-40 hp British diesels. That probably turned out to be a bigger disaster than fast hitch or 560 rear ends. In our cold climate we couldn't get the damn things going from Oct to May. I remember one farmer that bought two of these British diesels, saying it was good that he kept his Super C to use for a pup or tow start. The tow start was just to get them going in May, June, Sept. and Oct. July and August you could almost depend on them to start.
Even when they did start you couldn't stand the fumes from them. I think they were engineered for a different grade of fuel than we were used to in North America.
I don't think fast hitch was much of and issue to SMTA, 400, 450 and 560 tractor buyers. These guys had been trailer implement guys, and they never really budged from that until the semi-mount plow came along. As far as cultivators and disks went they never changed. I know on my own farm I had a used fast hitch corn planter that stayed around only two seasons. The fast hitches on my 300 and 560 were used almost entirely as drawbars, and they were damn poor drawbars. After I got the 656 I cut those two hitches up for scrap, and went to dealer and ordered two new Farmall H-M drawbars. The only 3 point equipment I ever had was a 200 gallon sprayer I used on 656 and a 5x16 semi-mount plow.
I had an IH dealer tell me 886 Farmall was the final straw for him. The first ones came with 360 American diesel. He had a lot of customers 50-60 cow dairy herds wanting that size tractor for forage harvester. His early sales of 886 sold a lot of tractors for him. When the customers found out how much less torque the 358 German diesel. What business he hadn't lost to MF, Ford and Fiat two decades before he now lost to Deere with the 886 engine change.
There is no CaseIH dealer in that town today, and my Farmall 560 was the only one ever around those parts, and it was an early 63 model, so no one there even knew of the 560 rear end failure. There were a few 460 gassers but those never worked well enough, long enough to damage a Volkswagon rear end.
The business blunders by IH were many, but probably the worst was arrogance, or was IH just ahead of its time. In my opinion the whole ag equipment industry operates that way today. I frequently go to dealers today for odds and ends. I can't believe my ears the way these guys talk down to farmers. I can tell you not many of them would be smart enough to sell this old bird anything.
CNKS
08-03-2004 18:29:34
 Re: What Failed????? in reply to Hugh MacKay, 08-03-2004 17:15:54
Where I grew up, in south Texas, there was more mounted equipment. I have pulled trailer type tandem disks, etc, but never a trailer plow. My Dad had an H with a semi-mount 3 disk H-M 150 -- same as a moldboard, except it used disks for our drier soils. Less draft made the H a "three plow" tractor for plowing. But the darn thing took at least 30 minutes to mount, and that's if everything lined up perfectly, an hour working alone is probably more like it. I would have loved 3-point or fast hitch then.
Richard Kline
08-02-2004 09:29:43
Around home the big JD's 4000 series had oiling problems in the new engines. It was a hp race and everyone was having their problems
The 560's were bought for big tillage. The gearboxes couldn't take it. The 806 cured the problem. The 504's were after the 560's and smaller. 50+ hp. We had two, and they were the all around workhorses and dependable as sunrise.
Bob
08-02-2004 08:51:33
Scotty,
If someone told you Deere went from the 720 to the 4010 without changing the driveline components they are slighly mis-informed.
I don't believe you will find a single powertrain component fron the 720 that was carried over to the 4010. Futhermore, the 720 had a "bull gear" final drive, and the 4010 had HEAVY planetary final drives.
Allan in NE
08-02-2004 11:17:43
 Re: What Failed????? in reply to Bob, 08-02-2004 08:51:33
Bob,
Yep, kinda wondered about that statement myself. Totally different rigs. :>)
Allan
john *.?-!.* cub owner
08-02-2004 07:44:44
Tractors as big as 560 were rare in my part of the country, but according to a dealer that came out and checked our neighbors, there was a problem with the axle bearing that carried the bull gear failing and the gear rubbing the bottom of the housing unitl it wore a hole through it. I would have thought you could have heard it, but they said no. They tested it by jacking up one side and watching for movement as they let it back down.
Hayfarmer
08-02-2004 07:05:42
I worked for JD during this era. I don't recall them having that much problem with rear ends but they were somewhat over engineered. The techs talked about some problems in the 4000 but was due to someone adding so much weight it coudln't slip. I think a limited amount of slip is like a slip clutch, a margin of safety.
Joe Evans
08-02-2004 06:41:49
Lineage line: M, Super M, 400, 450, and then 560. For the 460, it is the H, Super H, 300, 350, and then the 460.
The failures of the 460 and 560 drivelines really put a black eye on IHC despite their good faith effort to effect repairs in the field. In retrospect, I read that a lot of these failures occurred in areas of the country where the tractors were weighted to reduce wheel slippage to zero. More weight = more pull = more stress.
I was not aware of John Deere's similar problems--not updating drivelines for the higher HP engines attached to them, and not suffering the same black eye that IH experienced. It may be that buyers thought they had no where else to go. If the 4010s were failing, too, the IH alternative during that era was still the -60 series and their bad reputations.
I need to read Fay's article.
JD Kid
08-02-2004 08:23:34
 Re: What Failed????? in reply to Joe Evans, 08-02-2004 06:41:49
what about the IHC 504? where did that fall into the whole mox? just wonderin because your talking about everything below it and above it but not it. sorry just had to ask
Joe Evans
08-02-2004 11:09:35
 Re: What Failed????? in reply to JD Kid, 08-02-2004 08:23:34
The 504 belongs to the -06 series which came after the -60 series starting in 1963. However the 504 came to life in 1961. I read that the 504 is a descendant of the 340. Not sure I agree with that, but they do resemble one another.
Jimmy King
08-02-2004 06:05:58
Super MTA, 400, 450, then 460 and 560, with the same bull gear and pinions. The MTA,400,450, and 460 all about 52Hp. The 560 about 63hp, now my 460D not long after an overhual and was being used to do jobs my 756 did, for a while, on the dino turned 63hp. so what would a 560D do under the same conditions 75hp????
