Mag to Distributer
Ted
08-05-2004 06:07:12
It is funny how things come back. That is why I read every post on this Farmall site even if the subject is not one of my problems. A while back I was surprised to read that a magneto could be "jury rigged" to work like a distributer. I am working with a friend to rebuild not restore a cub. He is finnally to the tune up stage and he is questioning why the magneto has an external coil wired to it. Does any one know the proper way to make this conversion? Does the mag still use the same points that originally belonged with it?
lee
08-05-2004 07:51:49
 Re: Mag to Distributer in reply to Ted, 08-05-2004 06:07:12
keep the correct polarity on the coil.
Bob M
08-05-2004 06:27:48
Ted – The “conversion” uses the existing magneto points/condensor to control battery power to fire a standard externally-mounted ignition coil.
To make the conversion run power from the ignition switch to one of the external coil primaries. Then connect the other coil primary to the points terminal inside the mag. The old mag coil primary must be disconnected from the points (or the mag coil can be removed entirely).
Hope this helps!
Ted
08-05-2004 06:32:17
 Re: Mag to Distributer in reply to Bob M, 08-05-2004 06:27:48
Thank you Bob, I was hoping that you would be the one to respond. Ted---- Western NY
Bob M
08-05-2004 11:53:45
 Re: Mag to Distributer in reply to Ted, 08-05-2004 06:32:17
My pleasure Ted!
Where in soggy western NY are you located? I"m in SW Monroe county...
Ted
08-06-2004 03:35:41
 Re: Mag to Distributer in reply to Bob M, 08-05-2004 11:53:45
Clarence
Very wet. I lost more hay this year in one month then I did in my whole life. Field corn is not likeing it and the garden is really suffering.
Thank You
