Farmall 140 Sickle Mower from 3-pt. hitch
JackD
08-05-2004 07:31:08
I've installed a Worksaver three point hitch on a Farmall 140. Is there any reason to believe that I could get just about any sickle mower that attaches to a 3-pt. hitch to work as long as the drive shaft will reach the offset pto?
Thanks,
Jack
Hugh MacKay
08-06-2004 19:59:34
 Re: Farmall 140 Sickle Mower from 3-pt. hitch in reply to JackD, 08-05-2004 07:31:08
Jack: Problem is, I don't think you will find a 3 point hitch mower light enough that the work saver hitch can handle it. Mowers create a lot of off center weight.
The only completely mounted mower ever used on offset Farmalls was the A-16. That mower was bolted solid to rear of tractor and only mower bar was lifted. In the case of the A hand lever and SA by linkage to hydraulics. The top shaft on the A-16 mower lined up perfect with pto on an offset. The C, H and M versions of the 16 mower had the top shaft mounted about 1' to the right. Since these mowers were belt drive to the pitman crank, the top shaft could be placed to suit the tractor.
Most of those A-16 mowers I've seen were 5' cutter bar. Many of those tractors operated semi-mounted mowers with 7' cutter bar for years. I would tend to look for an older IH semi-mount, they can be mounted so drive shaft is straight line.
