Carb drip hole
Glen E.
08-18-2004 01:58:34
I have a '45 M and am rebuilding the carb. There is a hole in the bottom of the bowl. The I&T manual calls it a "drip hole" and shows to be some kind of packing in it. There is no packing in there. What should be in this hole? Would a wad of steel wool work? I would think you need something in there so its not just sucking in dirt.
Mike(IL)
08-18-2004 18:48:15
 Re: Carb drip hole in reply to Glen E., 08-18-2004 01:58:34
The last time I got a rebuild kit at case ih they also gave me a box that contained the packing and a little washer to hold in the packing for a couple of dollars.
Pete L
08-18-2004 09:51:21
As gas will wash out the oil to prevent rusting, suggest some bronze wool. Kinda like a steel wool pad, but most likely found at marinas for some boat cleaning.
lee
08-18-2004 06:26:09
I have used scotch brite.
rebuilder
08-18-2004 04:31:00
Glen E:
I use felt oil wicks which I use for starters and cut-to-lenght to fit in the hole. Steel woolwould work, but you must pack it in tightly and use a drop or two of oil to prevent it from rusting away.
Nebraska Cowman
08-18-2004 04:29:10
I would use a piece of wool felt.
