Most expensive part per pound from Case-IH!! (non
Bill in Orono,M
08-24-2004 16:20:13
Can you guess what it is??
Well I think it is the distributor cam for my '54 300.
Cater & Gruenwald price $382.00. They couldn't beleive it either.
Part #355724 R91 (w/felt)
I suppose then the 300 is worth say... $250,000?
Any one find this part for less??
The Red
08-25-2004 09:25:35
 Re: Most expensive part per pound from Case-IH!! ( in reply to Bill in Orono,MN, 08-24-2004 16:20:13
Thruster bearing for the H/M governor. I paid $65 five years ago. That part hardly weighs anything.
justin w
08-24-2004 17:46:02
You must have been quoted the wrong price.. My latest price file lists the retail price of approx $120. I have a NOS distributor cam for the H that changes the timing for increased power (IH produced changeover kit), but I doubt it would work in the 300.
Bill in Orono,MN
08-24-2004 17:55:14
 Re: Most expensive part per pound from Case-IH!! ( in reply to justin w, 08-24-2004 17:46:02
Luckily things are working fine without a new cam, be it $2 or $200. New high tension coil wire and new plugs and she purrs or roars...depending on what you like to do. I kind of like the 5th gear up a decent hill (decent for a flat land area any how) when the gov. opens her up.
Something wrong there.
08-24-2004 17:15:33
Don't know about 300 but 400 cap is same as A, B, C, H and M and they can be had for a lot less even at dealer. At least mine is distribitor could have been changed though.
MagMan
08-24-2004 17:09:51
you should beable to buy a whole good rebuilt for about $100.00 150.00$ for electronic ign. JON
Brian Schmidt
08-25-2004 12:47:15
 Re: Most expensive part per pound from Case-IH!! ( in reply to MagMan, 08-24-2004 17:09:51
MagMan,
Do you know where a rebuild distributor could be obtained?
Kelly C
08-25-2004 19:44:24
 Re: Most expensive part per pound from Case-IH!! ( in reply to Brian Schmidt, 08-25-2004 12:47:15
There is a guy in Rice, MN that rebuild Carbs and Dist for old tractors. I just got a rebuilt carb for my 460 and he showed me what he does to the distbutors.
Marks Carburetor & Magneto service
2189 125th st nw
Rice,MN 56367
320-393-7272
Fax 320-393-7273
Cell 320-420-9855
MagMan
08-25-2004 13:16:57
I have two here from cubs I am not exactly sure if there the same or not as far as 6vt 12vt deal. I sell them on ebay. That would be a good place to look. Also I have never installed electronic IGN But I sell them and that may fix your problem also becuase you do away with the points.Maybe some one else will step in and give us the answer. JON
