Broken Throttle Block on 300 Utility Carb
JTF439
08-26-2004 08:22:02
Does anyone know where to get the white plastic throttle block that links to the governor control from the carb.It is pressed on the throttle shaft and pinned.One of the ears broke off and the local Ih/Case dealer says its not available.I heard the OEM part was metal and the afer market one is the white plastic material.
Thanks
TractorTom
08-26-2004 10:33:33
 Re: Broken Throttle Block on 300 Utility Carb in reply to JTF439, 08-26-2004 08:22:02
I am a little confused by your description, do you mean the notched linkage arm that is connected to the throttle shaft? If it is, I may have a spare. I thought some of that kind of hardware came with the better carb kits. I will check later on today.
JTF439
08-27-2004 09:42:03
 Re: Broken Throttle Block on 300 Utility Carb in reply to TractorTom, 08-26-2004 10:33:33
It is the notched piece pressed onto the throttle shaft that the little governor pin goes into.It is part of the carb.I took the two throttle plate butterfly screws down in the carb off and the throttle pin with this piece I need pulled right out.
Let me know and thanks
Tractor Tom
09-16-2004 11:24:45
 Re: Broken Throttle Block on 300 Utility Carb in reply to JTF439, 08-27-2004 09:42:03
Sorry for the delay but I think I finally found the carb part you were looking for. Email me if you still need it.
