Hyrdraulic pump on IHC-H
Don E. F0ster
09-06-2004 14:10:37
Today I took the pump out of the reservoir on my '43 Farmall H. I replaced the grease retainer and discovered a broken piece in the bottom of the reservoir. It is the tip off casting # 5024-EA. This allowed a cap to come off the push rod that worked this rocker arm and I discovered it in the bottom of the reservoir. There is a spring remaining in the pump casting that connected to the broken tip.
Then the pump casting showed a wear spot under the broken rocker arm. ALSO another worn spot directly in the middle of the same casting and directly under the provision for the power drive shaft to the transmission. I cannot see what casued this wear!!! Bugs me!!!
I have good pictures which I can e-mail of this if someone wants to help me out and wants to see them.
I need advice and possibly a replacement for the broken rocker arm.
Thanks.
MagMan
09-06-2004 19:06:32
 Re: Hyrdraulic pump on IHC-H in reply to Don E. F0ster, 09-06-2004 14:10:37
That cap you are talking about is in the bottom of Most H Pumps It comes off sometimes when you pull The rod all the way back and it stays there untill you build full pressure then the valves kicks out and that cover falls off. I did something when I had mine apart the last time to get it to stay there better cant remember what I did now as for the rest I would have to see pics to tell what you are talking about I have a few pumps apart for parts if you let me know whay you need I am from NY. JON
Don E. Foster
09-06-2004 20:54:00
 Re: Hyrdraulic pump on IHC-H in reply to MagMan, 09-06-2004 19:06:32
MAGMAN, sure would like to have your E-Mail address so I can send those pictures. My E-Mail address is: dfoster3@sisna.com . Thanks
Boyd
09-06-2004 18:09:50
Don If it was mine I would buy another complete pump. That way you will have some parts if you ever need them. It would probably be the cheapest way for you to go. Luck Boyd
