B cutting out
Will-shooter
09-06-2004 20:25:15
Three years after a total tear down, my B has started doing something different. The other day while I was out mowing-with hardly any strain on the tractor- it started cutting out. I checked the carb, it was clear. No problems with the fuel line either.
Anybody got any ideas? This tractor has a Fairbanks-Morse FMJ mag on it with a Zenith carb. It's never given me any problems.
Thanks in advance!
Will
Dave BN
09-08-2004 01:50:02
 Re: B cutting out in reply to Will-shooter, 09-06-2004 20:25:15
Sorry for the late response, I don't always get to read the board every day. If fuel flow is OK I'd check the ignition system. Does it run OK again after it cools down? Were you running in damp weather? All signs of bad ignition parts. Could the coil wire be slightly loose? Check the ignition components and repost. Dave.
