IH 240 transmission leak
Dave D
09-14-2004 10:34:30
Just bought a 1961 240 with loader which runs great but is dripping gear oil at the joint between the trans housing and the left axle housing. (Right side is clean & dry.) I am catching about a qt. a day. Can I reveal & replace the defective gasket without pulling the left wheel? Is there an inner seal also that has failed for this to be leaking?
I don't have a parts manual or a diagram and I am flailing for an idea of how bad this situation is. Ideally looking for a way to do this in my yard with jacks and stands. Thanks for any thoughts or suggestions, gentlemen.
Coax
09-14-2004 11:57:22
 Re: IH 240 transmission leak in reply to Dave D, 09-14-2004 10:34:30
Are you Sure its the Drive Axel, or is it coming from the brake drum?
Dave D
09-14-2004 17:57:35
 Re: IH 240 transmission leak in reply to Coax, 09-14-2004 11:57:22
Hate to admit but I don't know the difference. It looks wet and I can watch it drip below the left axle housing where it exits the trans housing. Is the brake drum the round bulge fairly high and a bit forward of the axle housing? There is one on each side of the drive train. I can work on old car engines and the like. Never tractors before...
Coax
09-15-2004 06:04:14
 Re: IH 240 transmission leak in reply to Dave D, 09-14-2004 17:57:35
Yes,They are you're Bull Pinion Gears W/ the Brakes inside,There is a seal inside that starts leaking very easiliy.Otherwise the axel shaft is technically the one with the wheel on it.It also has a seal in it.Its not hard to fix just involves time.E-Mail me at attman6@wavecable.com,I'll see What I can Do to Help...
