Cleaning Farmall C Air Cleaner Assembly Question
Scott Swanson
09-15-2004 12:27:44
I found that my entire air cleaner assembly needs to be cleaned. Do I use Kerosene, Diesel, or Gas? I need to fill up a five gallon bucket to completely submerse it. I run the tractor without the assembly attached and it purs. I put the assembly on it and it chokes out the engine.
Any ideas or helpful hints?
Thanks to all,
Scott
gene
09-15-2004 22:17:58
 Re: Cleaning Farmall C Air Cleaner Assembly Questi in reply to Scott Swanson, 09-15-2004 12:27:44
Kerosene. Just let is soak for several days. Jiggle it up and down ever so often.
Actually I use my parts cleaner. I let the fluid run through the air cleaner for several hours. Then let the air cleaner soak over night in the solvent, then more fluid running through it.
CNKS
09-15-2004 18:12:13
I use parts cleaner -- Used gas for darn near everything when I was kid -- One spark and I'd be a dead kid.
Paul Shuler
09-15-2004 18:45:36
 Re: Cleaning Farmall C Air Cleaner Assembly Questi in reply to CNKS, 09-15-2004 18:12:13
A five gal bucket of gas just for cleaning parts gets pretty pricey these days.
JRB IN MAINE
09-15-2004 17:25:16
Use Gas it acts as a thiner. Just blow out real good with air hose before reinstalling .
