Battery for Farmall C
Jerry Ward
09-16-2004 05:48:09
Can someone tell me the physical size of the battery for a Farmall C? The tractor is 20 miles away from me and it needs a new battery (6V) and I would like to pick one on my lunch break. Is this something that a place like Murry"s Auto Parts would have? I know that there no extra room arround the battery so the size is inportant.
William W.
09-16-2004 13:29:39
 Re: Battery for Farmall C in reply to Jerry Ward, 09-16-2004 05:48:09
...And just a reminder, it"s probably a positive ground system.
Jerry Ward
09-16-2004 13:32:43
 Re: Battery for Farmall C in reply to William W., 09-16-2004 13:29:39
Yep it is. I have a Ford 2N that I'm used to working on, so I know enough to recognize a 6V positive ground system.
John in NE
09-16-2004 09:24:51
I just got one for my "H" and it measured app.7X9 inches.John
randy hall
09-16-2004 06:47:45
the battery size for your c is a group 1
Jerry Ward
09-16-2004 19:31:50
 Re: Battery for Farmall C in reply to randy hall, 09-16-2004 06:47:45
Thanks, the group 1 was the key. Best price in my area is AutoZone, $40.
TimV
09-16-2004 06:32:34
Jerry: Here in northern NY, any NAPA or similar will usually carry one of these in stock, and they have the books to tell you what size you need. It's a fairly common battery, and shouldn't be a problem. I got my last one off-the-shelf at NAPA--if you're in a farming community, it's worth their while to keep a couple around as lots of the older tractors used the same battery.
Brian in NY
09-16-2004 05:56:04
I don't know the exact size of the battery, but if you have looked at the old one and it is a 6 volt, you will know it when you see it. Try to get an actual tractor battery...they are better suited to being bounced around and beat up....I would be a little surprised if an auto parts store would have a 6 volt battery...you would be better off going to a tractor supply or central tractor type place. Just my thoughts...
Novel Idea Guy
09-16-2004 09:48:45
 Re: Battery for Farmall C in reply to Brian in NY, 09-16-2004 05:56:04
AutoZone and Advance Auto both carry Group 1 6 Volt batteries in this area, as does NAPA.
