300 U Battery Box
gwb
09-19-2004 12:19:20
The 300 U arrived with no battery box, just a bungee over the battery.
I see some boxes listed to fit it.
Question: does the 300U box have a top?
Question the second: Will any of the common 12V batteries fit in the stock box?
Question the third: Is there sufficient top clearance to use a marine battery box instead of the original for the time being?
mark k
09-19-2004 19:29:02
 Re: 300 U Battery Box in reply to gwb, 09-19-2004 12:19:20
Hello,
My 350 dosen't have a battery box and I tried to use a boat box and it was too wide. Length and height were ok but being too wide it sat in there cocked..
Mark
Dale Kite
09-19-2004 18:16:02
The 300 utility did not have what you would call a box, it had a frame that fit around the top of the battery with a hinged lid attached. The frame had long j bolts that attached to another part on the top of the trans. The lid flipped toward you to get to the cables. I found one for mine but it was rusty and needed work. Someone is making them new but they are about $100.Most people threw them away because they were in the way.
