544 electrical problems
alan robenalt
09-24-2004 18:58:31
after running it begins to squeal. i have a batt drain i cant trace. there is 5.4v to ground. i have tried i think all i know. what am i overlooking or missing? help me please
Allan in NE
09-25-2004 04:07:37
 Re: 544 electrical problems in reply to alan robenalt, 09-24-2004 18:58:31
Hi Rob,
First off, what makes you think that you have a drain? I don’t understand how are you measuring 5.4 volts on a 12-volt system. Where are you putting your leads to get this reading?
This just sounds like a simple matter of tightening the darned fan belt. Bad alternator bearings don’t squeal, they growl.
Allan
alan robenalt
09-25-2004 17:46:33
 Re: 544 electrical problems in reply to Allan in NE, 09-25-2004 04:07:37
when the - cable is unhooked from the batt i put the leads from - post to the ground w/ nonething on something is drawing 5-6 v. i have went through light & ign. switchs, changed voltage reg,checked ohms on resistors..... today while moving grain i noticed that when either the + or- cable is unhooked that the tractor dies. is this a good way to check to see if the alt. is working?
K.B.-826
09-24-2004 19:35:26
Is the squealing coming from the area of the alternator? If so the bearing is out. Have the alt. bench-tested just to make sure. Mabey the alternator is also causing the drain. Just start unhooking stuff until the drain quits.
alan robenalt
09-25-2004 03:11:15
 Re: 544 electrical problems in reply to K.B.-826, 09-24-2004 19:35:26
the drain occurs when nonething is running. i tried unhooking all components but haven't found yet.
