I took my Farmall H water jacket off
John in Ct.
09-27-2004 19:22:06
I took my Farmall H water jacket off. I will be putting a new one on. I flushed out the block until the water was running clear. I got all of the scales that I could off. I was wondering, will have a problem with the scales that I couldn't get off? After resealing the water jacket, thermostat, etc, should I put a flushing solution/with water in and flush out the block again? I want to use Caterpillar antifreeze with the coolant conditioner addative (for diesel engines that turns the test srtips red) in my Farmall H after it is all back together because I use it in all of my other things, will I have a problem using it? Thanks!!
Bob M
09-28-2004 05:34:48
 Re: I took my Farmall H water jacket off in reply to John in Ct., 09-27-2004 19:22:06
John - So long as you got all the loose scale removed and there’s nothing blocking the passages, the engine will cool just fine with the scale that’s left. Also as long as you get only clear water out when you flush the block/radiator before assembly there’s no need to flush it again after everything is back together.
Using Cat coolant + additive will work fine. Keep in mind the H cooling system was designed to work filled with untreated, muddy pond water...running Cat antifreeze will be a real treat for it!!
