Gas vs. kerosene vs. distillate
Kevin Brooks
09-28-2004 05:21:08
New to tractor restoration and have just recently received both the service and parts manuals for my '51 M. The parts catalog indicates different valves for use with gas, kerosene, or distillate. My tractor is equipped to accept either gas or distillate. What is distillate? I thought that referred to kerosene, at least until I saw all three types listed. What's the advantage of kerosene or distillate vs. gas?
Nebraska Cowman
09-28-2004 05:30:04
 Re: Gas vs. kerosene vs. distillate in reply to Kevin Brooks, 09-28-2004 05:21:08
kerosene and distilate are both heavier fuels that will produce slightly more heat units and hence more power under correct conditions. These were cheaper fuels in the old days but new refinery procceses have made for less kerosene and compleatly eliminated distilate fuel. These fuels used a lower compression head and that is why the valves must match the head. It does not matter if you are burning gas now; if you have a kerosene head you must still use kerosene valves. Check the casting number on the head and someone can tell you which head you have.
rustyfarmall
09-28-2004 06:15:05
 Re: Gas vs. kerosene vs. distillate in reply to Nebraska Cowman, 09-28-2004 05:30:04
Cylinder head part numbers-
8060- high compression gasoline
6336- kerosene
8777- distillate
I believe this is correct.
