Order Farmall Cub Parts Online
1958 cub needs new brakes
hope farmer
09-29-2004 18:10:08
I have a 1958 cub that is in need of new brakes. What kind of job is it to change brakes? Any special tools required? Any other parts that should be changed at the same time? Suggestions on where to get the new brakes? My local CASE dealers don't support the IH products (their loss).
George Willer
09-30-2004 07:35:46
 Re: 1958 cub needs new brakes in reply to hope farmer, 09-29-2004 18:10:08
A cherry picker to handle the weight of the final drives is a good idea.
Replacing the seals in the differential housing at the same time is a good idea, while you are there. These seals are often the reason for brake failure. The seals are often damaged because the finals are handled without a hoist.
George Willer
Bigdog
09-29-2004 19:28:50
You'll have to pull the final drive housings to change the brakes. No special tools, just time. Try Carter & Gruenewald for parts.
