504 c 153 gas engine
AgMan1
10-01-2004 17:06:02
A little help? 504 C 153 gas engine torque values for the following:
Connecting Rod Bolts?
Cylinder Head Bolts?
Can"t believe I found a piston, connecting rod and camshaft. Red will come back to life!!!!
Ben in KY
10-02-2004 17:51:53
 Re: 504 c 153 gas engine in reply to AgMan1, 10-01-2004 17:06:02
According to the IT manual.
For 504 non diesel...
Cylinder head bolts= 70-75
Connecting Rods= 40-45
Main bearing bolts = 75-80
Good luck :)
Shaggy
10-02-2004 12:02:58
Where did you get your camshaft? I have been thinking about putting one in a B just to get a little more power. Thanks shaggy
El Toro
10-02-2004 04:24:13
Hi, Give this number a call 1-800-732-0017 and ask for farm equipment service. They can supply the torque values you requested. Hal
PS: I think the rod torque is somewhere aroud 40-ft-lbs and head torque around 70 ft-lbs. Check
with this toll free number for sure. This torque
is used on the 152cid engine.
