tires for IH plow
crynearson
10-12-2004 15:43:06
I would like to know what size tires go on a 2-bottom IH plow. Any information will be helpful.
Hugh MacKay
10-12-2004 17:25:20
 Re: tires for IH plow in reply to crynearson, 10-12-2004 15:43:06
Do you know the model number of the plow? They are not all the same. I have information on about 45 IH models, and that is not all of them. Many of the trip lift plows had different size tire on each side. Not saying I have your info, but it's worth a try.
Randy SE-MN.
10-13-2004 05:38:10
 Re: tires for IH plow in reply to Hugh MacKay, 10-12-2004 17:25:20
Hugh: I have a model 60 3-16...would you have the tire recommendations for that one? Thanks...Randy
Hugh MacKay
10-13-2004 16:53:15
 Re: tires for IH plow in reply to Randy SE-MN., 10-13-2004 05:38:10
Randy: On No.60 3 bottom parts book shows 4.00 x 12 for the tail wheel. The front wheels it gives 4 options; 6.70 x 15, 7.00 x 14, 7.50 x 14 and 8.00 x 14. It shows the right wheel as a ribbed implement and left tire as ribbed implement for hydraulic lift, and traction tire for clutch lift. I had 3 of these plows on the farm, one 3 furrow and two 4 furrow plows, all hydraulic lift and if I remember correctly my plows were all 6.70 x 15, with 4.00 x 12 on rear.
MagMan
10-12-2004 16:23:18
I have always run 600/16s on mine old front tires from the farmall work pretty good. JON
