H Stuff
Allan in NE
10-15-2004 12:26:54
Okay,
Here's the deal. First ol' Harley '83 was good enough to sell me this pump and I wanna take just a minute to let you know just how honest this guy is. Thanks, Allen!
But, now I'm really dumb!
I think it was Brian in NY who warned me that this thing will peel the teeth off the timing gear if I just install it on a straight H without first changing all the other gears in the front cover. Can someone tell me why this is or why this would be?
I don't wanna ruin my tractor, but I don't wanna yank that front cover either. How come I can't just slap 'er in there?
Thanks Guys,
Allan
third party image
third party image
kfox
10-15-2004 21:40:11
 Re: H Stuff in reply to Allan in NE, 10-15-2004 12:26:54
The front cover on the H will have one bolt hole off about 1/4 inch. I just went through this last week. The SH & 300 frt covers will fit the pump. I haven'y been able to find the 300 timing geas yet, but I'm still looking. ken
Brian Schmidt
10-15-2004 19:00:50
OK, I guess I started this with reply to Allan.
To do this correctly for longevity, you will change out the front cover and gears with that of a 300. Everything else is the same.
I guess a fellow could run it until it quits then replace the broken pieces and hope that too many of the fines didn’t find their way into the crank and cam bearings.
If it was me, I would replace the cover and gears and forget about the belly pump and use the live pump for everything. You will have a much more useful tractor with live hydraulics on the loader.
Remember, all this is my limited opinion anyway.
Allan in NE
10-15-2004 20:13:19
 Re: H Stuff in reply to Brian Schmidt, 10-15-2004 19:00:50
Hi Brian,
Do you think that this type of pump can handle a loader? Didn't know that they were big enough for something like that??
Thanks,
Allan
Brian Schmidt
10-16-2004 12:55:32
 Re: H Stuff in reply to Allan in NE, 10-15-2004 20:13:19
I am no expert on this, but I have seen guys have these setups on 300s and 450s. Both using the factory pump and they work great with a loader. Should have as much if not more than your old belly pump. I am using the factory pump on a Super C to run a loader. This pump is about 1/4 the size of your pump and it works great. On my 300 I am using it to run a 3 point hitch on the back. I can pick up big round bales with it. Much more than the tractor was designed to carry. I don't do it too often because I don't want to be sitting on the ground when the rearend shatters.
Brian in NY
10-15-2004 13:39:46
Well Allen, I appreciate your thinking of me but being the rookie that I am I wouldn't even think of knowing enough to give you advice on those gears. But in retrospect and if you twist my arm I would probably go ahead and install the unit straight up and not be too hard on it at the limit. There is a case to made for "an ounce of prevention" of course and if you have the extra time and money to do the job 100% correctly now, it will perform as a Farmall (read: troublefree)for many years. Otherwise she might start actin like a sissy green tractor! Sweet Lord NO!
rustyfarmall
10-15-2004 13:19:18
Allan, If I were to give advise, I would advise you to change out the gears for the heavier set, but I also know of several Ms and Hs that were equipped with live pumps and have lived for years without changing out the timing gears. As long as you know what you are doing, and I think you do, then go ahead and stick the pump in there and go for it.
Stan(VA).
10-15-2004 13:00:25
The stress on the timing gears primarily comes when the pump is working against the relief valve (ie: you have run a hydraulic cylinder all the way to it's extreme and you're still holding the control valve forcing the pump into a high pressure situation). Those pressure reliefs are typically set up around 2000-2500psi (aftermarket valves like Cross) which is what will damage your gear train. Get a control valve with an adjustable pressure relief and set it on the low side (say 800psi or less. if you can live with 500-600psi, do it) then you will still be able to work, but without stressing those timing gears as much. And pay attention when you operate the hydraulics so you don't ever make the pump work against that relief valve. If you find you want more pressure, then pull the front cover and upgrade the gears on your terms (before they get shreded). An ounce of prevention ...
Stan(VA).
Allan in NE
10-15-2004 13:54:56
 Re: H Stuff in reply to Stan(VA)., 10-15-2004 13:00:25
Stan,
I appreciate you help and bear with me here, 'cause I'm dumbern' a 12" Cresent wrench and a pair of Vice-Grips.
All I want to run with this thing is a Char-Lynn power steering motor; that's it. Just in, thru and out of that little control/motor and then dump back to the can.
Would this work and/or do I have to rig a pressure control/bypass valve to make it work?
I know people use automotive pumps, but they already have the pressure relief built in to the pump.
Can ya help me one more time and give me your opinion?
Thanks,
Allan
Stan(VA).
10-15-2004 20:07:16
 Re: H Stuff in reply to Allan in NE, 10-15-2004 13:54:56
Allan,
I hadn't been following this whole conversation and was guessing just control of a 3pnt hitch. But Brian's response rung a bell and if you're the guy with a loader and wide front on his H then I agree with his comment that you will be much happier with the live pump on everything. You will need a priority flow diverter that feeds the PS motor and the aux valves for the loader and whatever else you want.
To answer the question directly, I don't think you want a low pressure relief on your steering circuit in this case. What little I understand about the steering motors is that they seem to try to maintain a constant volume, and pressure varies as required by load. With a wide front and a loader you are going to need to build some higher pressures (a full bucket trying to turn the wheels at a dead stop). Where the magic point is I don't know without trying it, but with a pressure relief valve you would just loose the power assist when you needed it the most.
If it were me, and I had the time, I would replace the gears and install the whole system at once. If I didn't have the time, I would install the pump for the PS motor temporarily and listen for a load on the motor as the sign that I was on thin ice and should back off (ie: don't try to turn without the wheels moving). You've heard the old mechanic's line, "You can pay me now or pay me later.". With that much hydraulic load you will want it done right as soon as possible.
Stan(VA).
Allan in NE
10-15-2004 20:51:41
 Re: H Stuff in reply to Stan(VA)., 10-15-2004 20:07:16
Stan,
Well heck. I didn't realize that these things had that much umph.
If you guys think it will handle the power steering as well as a F-11 loader, then I'm gonna put in the whole schmeal; gears, cover and all.
I think you guys just made my day; that would give me 'live' all the way around!
Thanks for your help,
Allan
Jrry
10-15-2004 12:46:08
Allen, "I have a plan" that will make it work. Just trust me on this. LOL
Novel Idea Guy
10-15-2004 12:42:56
Cuz... Notice how thick the gear is on the pump? The stock OEM gears under the timing cover in the H are about half as thick, as I understand it.
You could pull the distrubutor and see for yourself. Who knows? Somebody may have already replaced the timing set.
wh
10-15-2004 12:41:51
been told that the original gears would not stand up to running the pump. not sure how long it takes to wear out the gear. put a live pump on a 45 h around 1990. it is used around 75-100 hours a year. still running the gear. did change the front cover. one bolt (top right i think) will not line up. some say to screw bolt in cover/saw off smooth/redrill to match pump/thread new hole. i just bought a used cover for a 300. all this to say - if doing it again i would not change timing gear
