856 Diesel injection pump
Weldon
10-17-2004 14:55:08
My 856 , operated by a hired man,ran out of fuel .( Yes, the guage works. )He immediately shut it off as it began to die. He added fuel and it started without venting the system. Used the tractor to blow about 15 loads of silage. When throttle was pulled back to idle after the last load, the engine shut off and would not restart. Hired man told me it had nearly shut off several times when he throttled down between loads. I vented the system per operators manual and had a full flow of fuel to the pump but engine would not start. Quit for the day and tried it next morning. Did not start after venting the system again and trying a shot of ether. No smoke of unburned fuel came out exhaust as usually does for a few seconds on a cold engine start. Borrowed friends 706 to finish the silo. When time permitted I removed the hood to get at the fuel line connections at the injectors, loosened them and turned engine over until fuel was spurting out at all injector connections, tightened connections, gave it a shot of ether and it finally started. After starting, as throttle is advanced, engine is very slow to rev up to full speed and at times will continue to increase speed beyond where throttle setting should allow.Also when throttled down quickly to idle posistion , engine shuts off but is no problem to restart. Anything you guys can suggest I try , short of removing pump and sending it to repair shop? Was pump damaged that quickly from running out of fuel? Tractor had this rebuilt pump on it when purchased wih 2900 hrs. in 1987. Now has 5664 hrs. Do Roosa Master pumps have a life of only 2500 - 3000 hrs.? Thanks for any suggestions . Weldon
Spencer
10-17-2004 16:43:11
 Re: 856 Diesel injection pump in reply to Weldon, 10-17-2004 14:55:08
Hey,
On the bottom of your fuel tank theres an elbow you might want to take that off and blow it out with a air hose. There might be some rust and junk from the bottom of the tank that got in there. Spencer
Red Green Man
10-17-2004 16:42:41
Sounds like the rubber governor ring is coming apart in your injection pump to me, pieces of it will block the return line and it will act squirrely. Pump will need a new kit put in it.
ErnieD
10-17-2004 16:31:11
You may want to try a new filter, taking the last dregs of fuel may have some dirt.
Allan in NE
10-17-2004 15:04:54
Weldon,
I think you still have air in 'er as evidenced by the tractor wanting to die at idle. Can you get her into a hard pull and let it run for an hour or so? That should purge that air out of the return circuit.
Just my guess,
Allan
Tim Malin
10-18-2004 10:36:20
 Re: 856 Diesel injection pump in reply to Allan in NE, 10-17-2004 15:04:54
That's what I was going to say. Do something with it to work it for a while to remove all of the air. However, if it is right about the rubber gasket, would you create a bigger pain in the rear end? Hehe, just my two cents.
