farmall M hydraulics
Carlton
10-18-2004 18:39:05
On an M with a belly pump how do you get hydraulics to the rear or to the front for a loader?
Carlton
MM_TX
10-18-2004 22:24:23
 Re: farmall M hydraulics in reply to Carlton, 10-18-2004 18:39:05
The loader will work a lot better if you add live hydrolics with a distributor pump. There are a lot of discussions in the archives about how.
Aces
10-18-2004 19:06:18
Carlton you will have 1 (1/2" pipe) coming out the right and 2 on the left you can use the 1 on the right or the front 1 on the left either 1 will lift the loader but you will only have lift if you have a hydraulic bucket you will need to add a 2 spool valve run a hose from 1 of the outlets on the belly pump to the inlet on the valve and from the outlet of the valve bcak to the fill port on the right top of the pump tie the belly pump lever back and use the valve you added.
