pipes or bolt at engine temp sensor?
Kevin Brooks
10-19-2004 11:00:15
My '51 Farmall M has a bushing or sleeve that accepts the engine temperature guage - screw into the cylinder head. When I unscrewed the sensor I noticed plenty of rust and gunk on the end of it. I then removed the bushing or sleeve at the cylinder head and the threads were very deformed and filled with rust. I tried to clean but it looks like the best approach is to retap the hole. The best I an figure is the hole is a 3/4" x NF14. I have called every hardware and autostore I can find and no one has such a tap. Is this a pipe hole? What have others used to retap/reclean this hole?
gusc
10-19-2004 22:11:07
 Re: pipes or bolt at engine temp sensor? in reply to Kevin Brooks, 10-19-2004 11:00:15
As old says it is a NPT. The bushing is what I call and adapter to allow different sizes to be used.
Any auto supply or hardware will have these. I recommend you get brass which will eliminate the corrosion problems, steel is the very worst type to use.
old
10-19-2004 11:04:00
that should be pipe treads if its like all the other tractors I've put temp gauges on.
