2 Point to 3 Point Conversion
GooseCreek Farm
10-25-2004 03:46:19
Recently purchased a Farmall 460 with a 2 point hitch. I know you can purchase arms/extenders that go into the 2 point arms, but how do you set up the "center link" attachment to the tractor? An explaination or even pictures would be great. I appreciate your help.
Redrider
10-25-2004 21:23:55
 Re: 2 Point to 3 Point Conversion in reply to GooseCreek Farms, 10-25-2004 03:46:19
third party image
Here is a flail mower with a IH 2 point adapter.
Redrider
10-25-2004 21:18:56
third party image
This is how I have all my 3 point equipment set up with a IH two point to 3 point adapter.
Jim J
10-25-2004 20:25:55
I make a top link bracket for the 460. Email me and I will send you a picture otr the bracket.
RayP(MI)
10-25-2004 18:18:57
Go to worksaver.com. Look at their rear hitch conversions - 2point, and look at the line drawings for HK 126 and HK 132. See of that makse any sense. I have their conversion on a Farmall 200, a different kit but it works well.
r4etired
10-25-2004 16:36:18
There should be 2 tappings in the the lift arms on each side. take a piece of 1/2 X 2in flat steel bend it to fit from the holes to the rock shaft then to the holes on the other side. Cut 2pieces of the flat stock 21/2 in long. Drill a 7/8 in hole in them , weld them in the center for your top link. If you use a strap around the rock shaft for the top link it is pretty sloppy when using a blade or any down pressure attachment MY 2 cents worth
Novel Idea Guy
10-25-2004 06:36:19
The top link is basically strapped to the rockshaft of the fast hitch. A simple flat steel strap bent in a U shape with a hole in each end makes a clevis that you attach the top link to. It doesn't matter that the "eye" on that end of the top link is sideways, because the whole thing pivots on the rockshaft.
Novel Idea Guy
10-25-2004 06:34:53
Evan350
10-25-2004 08:10:28
 Re: 2 Point to 3 Point Conversion in reply to Novel Idea Guy, 10-25-2004 06:34:53
A while ago I posted a picture of my 350 with a 2pt #100 mower mounted. However, if you look at the photos, especially the one looking right at the back of the tractor, you'll see the described top link attachment. Go to implement photos and search on 'balance' to find my pix.
