WD-9 Serial Number
maestro
11-09-2004 19:09:15
Can anyone decode this serial number? (year etc.)
WDC61331W16
It is also equipped with power steering. Is this a factory option? Anything else you can tell me?
farmaller
11-10-2004 04:17:42
 Re: WD-9 Serial Number in reply to maestro, 11-09-2004 19:09:15
Should be WDCB61331W16 should put it as 1944. W16 means optional overcenter clutch (hand-operated)
Maestro
11-10-2004 20:03:33
 Re: WD-9 Serial Number in reply to farmaller, 11-10-2004 04:17:42
What do all the other numbers at the beginning mean? WDC61331W16 I know the W16 means hand clutch, but the WDC or WDCB?
If it is a 1944, wouldn't the serial number be a high 4 digit number?
Farmaller
11-11-2004 16:35:23
 Re: WD-9 Serial Number in reply to Maestro, 11-10-2004 20:03:33
I made a mistake on the no. It should be 1952, W for wide or wheatland maybe. D is for diesel. CB not sure. Mine is a 52 also it should have X code on the frame date.
