What kind of oil(s) to use in M
7lazy77
11-10-2004 10:05:31
I have just purchased a 51 M & live in Wyoming where the weather can get cold at times. Year around temperatures range from -15 to +90 degrees. I was just wondering on what kind of oil to use in transmission & crankcase and to get some input. Can I get by with just one weight year-around?
Tim Malin
11-10-2004 20:41:53
 Re: What kind of oil(s) to use in M in reply to 7lazy77, 11-10-2004 10:05:31
Hey, here in Wisconsin is the same deal, I know I was outside at least one day last winter (had a house fire call, had no choice but to be outside) when the air was -18 degrees F. Anyway, I run a heavy duty Cenex 10W-30 Diesel engine oil in my Super M crankcase. Standard 80W-90 in the transmission will be fine. Things aren't moving fast enough to need a super duper fluid oil. Leaves a nice coat on everything. That's all you need. Good luck.
Bob M
11-10-2004 10:52:26
We see about the same temp range here in western NY - which incidentally Wyoming NY sits smack in the middle of...
Anyway in the crankcase I've run 15W40 year round in my Farmalls for many years. If yours has high compression pistons and has stock 6 volt electrics you might switch to 5W30 in winter to ease starting - but it probably isn't necessary.
I have 80W-90 in the transmissions - it works fine throughout the temperature range here.
Ben Rauls
11-10-2004 10:56:09
 Re: What kind of oil(s) to use in M in reply to Bob M, 11-10-2004 10:52:26
You say 80w90 in trans and diff? For the m hydraulics what do you use? I s there a sererate resivor so to speak for the hydraulics?
Bob M
11-10-2004 11:34:31
 Re: What kind of oil(s) to use in M in reply to Ben Rauls, 11-10-2004 10:56:09
Yeah Ben - both the live and countershaft driven hydraulic systems are independent of the tranny/final drives on the lettered Farmalls. I use plain old 10W hydraulic oil (purchased at Sam's Club, Autozone or wherever it is cheapest) in mine...
7lazy77
11-10-2004 10:41:14
Wyoming USA
farmallman
11-10-2004 10:15:07
just wondering.....Wyoming as in State of USA or Wyoming as in Ontario, Canada?
