M live hydraulic pump drive gear
jamiei
11-14-2004 08:54:46
I have a M and W live hydraulic pump that the distributor drive "bushing" is worn and I would like to replace it. Anyone have any idea where to look for it or if its available? I thought about trying to use the bushing off the tractor's magneto bracket but the mounting of the bushing to the shaft looks different than whats on the m and w pump. Anyone have any ideas? Looks like the distributor was loose maybe is what caused the bushing to be damaged like it is. I bought the pump on ebay as "works great" only to find the bushing was damaged. Hopefully the pump works but I'm afraid to test it without changing the bushing cause I'm afraid it may throw off the timing. I'll be glad to supply the user id of the seller to anyone that doesn't want to run into the same problem.
williamf
11-14-2004 15:15:54
 Re: M live hydraulic pump drive gear in reply to jamiei, 11-14-2004 08:54:46
If you don't find a source though the net, you might try calling around. Walt's Tractor Parts at 888.414.4043(free) or Joe's Farmall at 814 226 6214 or Carter & Gruenewald at 866 327 6255(free). Even if none of them have it one of them might can steer you towards it. I've found all three to be helpful folk. Good luck,
Wm
rustyfarmall
11-14-2004 09:01:52
Have you tried to work things out with the seller? If you have, and recieved no satisfaction, then I hope you have left negative feedback for the seller. Other that that, I can't help you out much.
