Super A Final Drive
Jack in OH
11-16-2004 06:04:17
I recently got a Super A and wanted to check all the fluids. I can't find a plug on the final drive units to check the gear oil level. My Cub has a plug in the casting to do this. Am I blind or didn't IH put one in?
Thanks
Jack
Duner Wi
11-16-2004 06:18:05
 Re: Super A Final Drive in reply to Jack in OH, 11-16-2004 06:04:17
The plug is hiding behind the draw bar mount as I remember.
Jack in OH
11-16-2004 06:41:08
 Re: Super A Final Drive in reply to Duner Wi, 11-16-2004 06:18:05
I removed the drawbar and the idler pulley assembly for the belly mower and I don't see one. How are you supposed to check or add fluid?
Jack
Red Dave
11-16-2004 06:45:35
 Re: Super A Final Drive in reply to Jack in OH, 11-16-2004 06:41:08
On the inside of the drive, toward the front. Just about the same level as the drawbar mounts to, there is a plug. It has a square indent that a 1/2" ratchet or breaker bar will fit into. Fill until you can just stick your finger into it and touch oil.
