removal of super M radiator
jnewark
11-17-2004 05:02:21
greetings
I have a super M with a leaking radiator, I am in the process of removing the radiator, my question is how do you remove the steering linkage, do you remove the top plate on the steering box, and also while I can get to it seems there was discussion about flipping the gear over to remove slop in the steering.. thanks in advance
jack ps, I am looking for NH baler knotter parts..
Bob M
11-17-2004 05:58:56
 Re: removal of super M radiator in reply to jnewark, 11-17-2004 05:02:21
Allan’s correct about removing the front cap and “unscrewing” the shaft out of the steering box.
The pivot shaft worm gear cannot be flipped over - it’s on a tapered spline and only fits one way. However if it is a full gear it can be ROTATED 180 deg and reinstalled. On the other hand if it is a sector type (half moon shaped) gear you are outta luck – it can only be installed one way.
Note: If your steering is sloppy check also for wear on the pivot shaft bushings – especially the upper one. If you find ANY radial play in the upper bushing it should be replaced while you’ve got the front end apart!
Allan in NE
11-17-2004 05:10:38
JNE,
Pull that front plug in the steering box; the shaft will then "unscrew" itself forward. Be ready to catch the oil that will drain outta there too.
Allan
captaink
11-17-2004 06:04:40
 Re: removal of super M radiator in reply to Allan in NE, 11-17-2004 05:10:38
Oil? Aren't you being kind of optimistic here? Most of what I’ve seen “ooze” out resembles the stuff the highway department uses to seal the cracks in the asphalt roads around here. LOL (Just giving you a bad time, hopefully the tractor was well taken care of and is still almost full of oil.) :>)
Have a good one!
Bob M
11-17-2004 06:24:54
 Re: removal of super M radiator in reply to captaink, 11-17-2004 06:04:40
You got THAT right! The two I've repaired contained nothing more than air when I opened them up - the oil had leaked out probably back when gas was still 29 cents.
Tip: After reassembly pack the gearbox full with a good wheel bearing grease. It'll lube the gears as well as oil - and it won't leak out the bottom seal!!
Andy Martin
11-17-2004 12:09:57
 Re: removal of super M radiator in reply to Bob M, 11-17-2004 06:24:54
Or good gun grease.
The next trick is to get the nuts off the bolts inside the lower casting. They are hard to reach and used to have castle nuts with cotter pins. Above the nut is a washer and spring. It's a tough place to get a torch so soak the threads for a week or so before you start trying to get the nuts off.
Bubba
11-20-2004 22:34:33
 Re: removal of super M radiator in reply to Andy Martin, 11-17-2004 12:09:57
I've been working on my Radiator on my M. I have found if I use short wrenches (the little stubby ones) I can get to the crown nuts a lot easer. Also, spray the crown nuts with WD40 or somthing like that and let them soak; the task will be a little easer to muster.
Harley
11-17-2004 10:43:58
Guys, we're in real trouble here if that old sandhills farmer is already starting to hallucinate after just one little bitty snow. Oil. good grief. Silly Nebraska farmer. Can we say "Grease", and maybe not much of that either, HAHAHAHAHA, Later, Harley
Allan in NE
11-17-2004 13:26:45
 Re: removal of super M radiator in reply to Harley, 11-17-2004 10:43:58
All right, you guys.
This is just simply a result of my superior thinking and high-level intellectual behavior..... ????? ? :>)
Dis is da reason I paid wayyyyy y tooooo o much for this old H. She had been thoroughly restored (and I mean thoroughly) prior to my sending the check.
Opened up the box, clear full of 'new' oil, new gasket and new seals all the way around. "0" shake or slop in the front end.
Checkbook is still smarting a little tho. :>)
(And 'sides that, it's my story so let me tell it the way I want to!) LOL!
Allan
