Farmall I4 and W4
Max(ia)
11-30-2004 14:23:08
I see there is one each I4 and W4 in the Photo Ads, was wondering what"s the diffence between the two. thanks Lee
Max(ia)
12-01-2004 06:25:29
 Re: Farmall I4 and W4 in reply to Max(ia), 11-30-2004 14:23:08
Thanks guys for the info. I have been thinking about buying a good W4or SW4 to have around, so I thank Dave for his info on the Canadian. Thanks again Max
Dave from Wis.
12-01-2004 00:05:52
Hey Max- i think everyone pretty much answered your ??"s - but i just felt obligated to offer a bit of advice (warning) ....if you"r condidering the W4 from Dave Pearson in Can. - be carefull ! he trimed me to the tune of several thousand $$$ a couple years ago on a load of tractors - he did"nt just stretch the truth or misrepresent ..... .he outright lied ! running tractor with stuck motor -- huydraulics , fenders , weights , carbs ,distributors, water pumps , generators (etc ,etc) all missing - like new tires that you could stick your fingers thru the sidewall (etc,etc)..... ..BUT , on the possative side - he"s the only crook i"ve ran into in the tractor bussiness ! hope these comments are not inapropriate-normally i figure if i can"t say good about someone , then say nothing - but this guy was so extreme - just hate to see someone else get burned
Paw Paw Dave
11-30-2004 18:21:03
W-4 was McCormick-Deering, I-4 was International.
Yeah, same thing, just different.
I-4 had the same engine, frame, sheetmetal, steering gearbox, and various accessories. Differences include a much thicker transmission cover, foot throttle, much thicker rear wheel discs. Drawbar supports were mounted different also, hung from the trans cover.
Don't really know about the transmission gearing or governor setting, mine started life as a O-4 but was converted at the factory and sent to Fort Wayne truck prior to being sold. Many were special ordered and so the variances were many.
Dave
Shaggy
11-30-2004 21:12:58
 Re: Farmall I4 and W4 in reply to Paw Paw Dave, 11-30-2004 18:21:03
Are you from the PAW PAW just north of RT80 and a few miles east of RT39? Just curious, I live in Naplate and I usually make the tractor pull there.
Shaggy
Paw Paw Dave
12-01-2004 17:54:25
 Re: Farmall I4 and W4 in reply to Shaggy, 11-30-2004 21:12:58
Nope, Paw Paw, Michigan. Right on I-94 just west of Kalamazoo, SW part of state. Dave
John M
11-30-2004 15:49:23
Foot throttle on I-4,maybe heavier front axle,faster gears,different fenders and platforn than w,but other wise the same.Oh,engine speed was up a tad I think.
Harold H
11-30-2004 18:22:23
 Re: Farmall I4 and W4 in reply to John M, 11-30-2004 15:49:23
That's about it except different standard wheels and hitch also. I4 is a International, W4 is a McCormick or McCormick Deering, H is Farmall.
Harold H
