How much are hyd. pumps, and how hard to install?
Bryce Andreasen
12-03-2004 23:15:18
I posted earlier, about my power steering problem. If i pull a hyd lever, the power steering is absolutely wonderful, but only for a maximum of ten seconds, then it locks up, and it takes a while before it works again. I have tested for PSI before, and it is about 300 psi below normal, so how much are hyd. pumps, where do i get them, and how big of a hastle are they to get on?
Hugh MacKay
12-05-2004 02:27:12
 Re: How much are hyd. pumps, and how hard to insta in reply to Bryce Andreasen, 12-03-2004 23:15:18
Bryce: I tend to agree with tractor vet on this. Hydraulic pumps aren't very notorious for healing themselves, not even for that moment when you activate that valve.
the tractor vet
12-04-2004 08:05:29
It sounds to me like you have a problem in the valving more then pump problems , if you have to short out a valve and you get steering then more then likely you have our it happened before you got this tractor that the littel plug between the valves blew out and now the steering pressure is bypassen. or the flow divider is sticking and your pressure regulator spring is weak.
old
12-04-2004 06:34:00
Depends on the tractor, one for a farmall 450 is around $600.
Nebraska Cowman
12-04-2004 04:00:02
it sounds like you have pressure enough, it is just not routed properly.
Old Mekannik
12-04-2004 03:40:51
About a hundred dollars and a hole lotta work plus tax.
